Batch Model - Group Sockets
I have the following situation:
- 3 groups of sockets,
- each group has 30 sockets,
- 60 sockets total.
Each group is one fixture in climatic chamber. All fixtures are in the same chamber at the same time, creating one batch. Unfortunately temperature in each fixture differs, therefore I want to make batch serial synchronisation of groups.
In example:
I set the 80 degrees in chamber. Fixture 1 reached the temperature but, fixture 2 and 3 not, so fixture 1 can start the test and fixture 2 and 3 needs to wait for the proper temperature.
Currently I'm using batch serialization (I'm using shared HW). One thread sets the chamber and waits for the temperature in all fixtures, and then tests are performed in series.
Any idea how to do this sockets grouping?
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(3,069 Views)
when you say 3 groups of sockets does it means  that you run 3 Executions? or 60 executions at same time?
CLAD, CTD
(3,042 Views)
60 executions (plus one for batch controller)
Michał Bieńkowski
CLA, CTA, CPI
(3,034 Views)
 wow that's a lot of sockets and switching hardware...fun project
CLAD, CTD
(3,032 Views)
