NI TestStand
Batch Synchronization Example TestStand 3.1
This TestStand 3.1 Example displays the three types of Batch Synchronization steps available and demonstrates their capabilities.
To place a batch Step, right click » Insert Step » Synchronization » Batch Synchronization.
Right click the Batch Synchornization step and Configure Batch Synchronization.
For each Batch Synchronization step you'll want to select whether you are Entering or Exiting. Place the code you want Synchronized between an Enter and an Exit.
For an Entering step you'll also be able to select which type of Synchronization you want. The three types are briefly explained and demonstrated.
Message 1 of 1
(23,695 Views)
