NI TestStand
Batch model UIMessage adjustments
Is there anyway to show failed step at the UIMeassage generated by postuut sequence of Teststand?
BTW the sequential model i use is batch model
(3,400 Views)
Hedehodo,
 This is Ali from National Instrument's applications engineering. I will be helping you with your issue today. Have you had a chance to Using TestStand User Interfaces or Best Practices for TestStand UI Development. The Using TestStand User Interfaces does include a custom example on how to have custom messages.
Additionally, here is some more detailed information on some of the properties you would be dealing with:
Example for Operator Interface
Displaying Custom Bar
Memory issues that might come up with customization (I would keep this on file but it shouldn't seem to be an issue for you)
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x1w9CAA&l=en-US
Ali S.
Applications Engineering
(3,378 Views)
Actually i need to edit TS standard messages especially while showing test result at batch model
(3,321 Views)
Hedehodo,
 Just to be clear you would like to edit the results to show more detailed information or to customize results.
Are you trying to remove information/add/ or try to change how things are showing?
Ali S.
(3,303 Views)
