NI TestStand
TestStand 2013 - Edit VI button disabled
Hello to everyone,
I am using TestStand 2013 development system, and I also have Labview 2009 SP1 Full development system.
I introduce a step with a labview action in my sequence. The Edit VI button is disabled, with the message "Requires LabVIEW Development System"...
Anyone can help me?
Much thanks for your time and dedication!
(5,658 Views)
Accepted by topic author Output
What is your LabVIEW adapter set to?  Is it set to use the development enviornment or is it set to use the run time engine?
You can check by going to Configure>>Adapters...
Choose LabVIEW and select Configure
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(5,653 Views)
Have you run labview on the system at least once?
-Doug
(5,647 Views)
Hello Doug,
Yes lots of times...
If I launch 1st labview and 2nd TS the problem is still there, If I lanunch1st TS ans 2nd Labview the same...
It doesn't matter if the VI has input / output parameters or if it has not....
I imagine that it must be some configuration of TS but I don't know what...
(5,632 Views)
Are you launching both SeqEdit and LabVIEW with the same user privileges?
Regards
Anand Jain
(5,629 Views)
~jiggawax~ I didn't see your answer before, yes it was what you say, I didn't remeber I modified this configuration!
Thanks to all.
(5,628 Views)
I also encountered the same problem
I break down
I has experimented with many ways
(3,825 Views)
