NI TestStand
Batch model resource management with step order flexibility
Hey, Teststand folks.  What's the best way in Teststand 2014 to do this?  I'm setting up testing 4 UUTs in parallel using the Batch model.  The test sequence has two parts.  2 UUTs at a time can run Part 1.  While 2 UUTs are doing the Part 1 test, I want the other 2 UUTs to do the Part 2 test.  Then when they're done Part 2, wait for Part 1 slots to become available and then run Part 1.  And those UUTs that had run Part 1 first will then run Part 2.
Thanks.   -Joe
Joe Czapski
Sonos
Boston, Mass.
Joe Czapski, Sonos, Boston, Mass.
(3,810 Views)
Accepted by topic author Station3
If I understand correctly, an Auto Schedule step at the top level would be perfect for this:
Auto Schedule
   Use Auto Scheduled Resource ("Part 1 - Slot 1", "Part 1 - Slot 2")   // these are two different resource alternatives
      // steps that do part 1. Use the Acquired Lock output if you need to know which slot
   End
   Use Auto Scheduled Resource ("Part 2 - Slot 1", "Part 2 - Slot 2") // these are two different resource alternatives
      // steps that do part 2. Use the Acquired Lock output if you need to know which slot
   End
End
(3,807 Views)
Hi, James. Wow you're right, the Auto Schedule feature fits the bill. I'm looking at the NI example 'Comparing Resource Usage Strategies.seq', subsequence 'Auto Scheduled With Additional DMM'. That is neat - will try it.
Thanks.   -Joe
(3,798 Views)
