NI TestStand
TestStand menu, how to show & hide
I have a copy of TestStand where the menu (File, Edit, view, Execut, etc.) is not visible.  How can I make it visible?
(4,077 Views)
What happens when you hit Alt+V?  Hopefully, you can navigate to "Reset UI Configuration..." in the View menu after hitting Alt+V.
Pulido Technologies LLC
(4,061 Views)
Hi Threads,
Like pulidotech said, you should be able to reset the UI configuration by hitting <Alt+V> and holding <Alt> whil hitting arrow keys until you reach that option. you can then customize your UI using the options here (more details in the TestStand Help).
(4,044 Views)
