NI TestStand
Best NI TestStand User Interface Documentation
Hi everyone, I am looking to update the Simple Test Executive User Interface that NI TestStand provides.  More specifically I am looking to customize the Simple Test Executive User Interface (i.e. adding controls and indicators, etc...).  What is the best documentation to read through that will get me started on customizing the Simple Test Executive TestStand offers?
Thanks!
(4,541 Views)
The  best one I've seen is the TestStand II course.  They have an exercise where you do exactly that.  Or at least they used to.
Here are some other good reads:
https://www.ni.com/en/support/documentation/supplemental/08/teststand-user-interface-development-bes...
https://www.ni.com/en/support/documentation/supplemental/12/working-with-the-teststand-simple-user-i...
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x3tWCAQ&l=en-US This one is good for UI Messages which allow you to get info to and from the sequence file to the UI.
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,515 Views)
