NI TestStand
How to build the lookup string for get the "additionalResult" info
Hi All,
     how to build the lookup string for get the "LowSpec" from the "additionalResult";I use "Locals.ResultList[1].AdditionalResult[0].Parameters[0].LowSpec" can't the target info and return an property name error.
(4,589 Views)
Try something like the attached image.  I think you will have better luck.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,571 Views)
Thanks,I can get the "LowSpec" value by you method!but I get the "MeasValue" that is an numeric array,it's no error but return empty array,I use TestStand 2010 and LV 2010;
(4,540 Views)
I'm surprised that doesn't work.  If you probe the variant wire does it contain any information?  It should.
You may have to get your MeasValue array as a property object and then iterate through it's subproperty 1 by 1 unfortunately.
jigg
CTA, CLA
testeract.com
(4,525 Views)
