Break on First Step stops in StationCallback Sub-sequence
Hi David,
I was able to reproduce your issue in TestStand.   This was reported to R&D (4GQBIQUY) for further investigation.  Thanks for the feedback!
Matt S
Message 11 of 15
(1,225 Views)
Thanks for your help!
Is there any way I can track the status of the issue? I want to be sure to install the patch when it is avalible. Also I have noticed there is a 4.0.1 version of TestStand. I have not been able to find any documentation showing the fixes from version 4.0, so I am wondering if there is a chance this would fix my problem? If not should I install this anyway?
David
Message 12 of 15
(1,204 Views)
Hi David,
You can track your issue by using the ID listed in the previous forum post (4GQBIQUY).  When we release new versions of TestStand, we include in the “Doc” folder a readme.html file which shows what issues have been fixed.
As far as TestStand 4.0.1, the issue is still present as I have tested it on my end.  However, if you do have a version of 4.0.1 available, I would suggest installing it as other issues have been fixed.
I hope this helps!
Matt S
Message 13 of 15
(1,198 Views)
I figued that was a tracking number, however when I entered it in the "Support Request History" form on the Support page I received an error. Is this the correct place to track this?
David
Message 14 of 15
(1,195 Views)
Hi David,
That page is designed for different purposes and wouldn't really accomplish what you are looking for.  Your best bet would be to check the release notes when a new version of TestStand is released as those should include what issues have been fixed.
Thanks!
Matt S
Message 15 of 15
(1,183 Views)
