Bug in Test Stand 4.0
here i found a bug in TestStand 4.0.
see attached VI.
I have built an exe with this VI (uses .net sub VIs) and installer in LabVIEW 8.5 and the installer works fine on target coputer.
The same Vi is used as a code module in Test Stand 4.0-Sequence-Step (LabVIEW Adapter).
After creating a successful installer in 4.0, i installed the same on Target Computer.
I found the attached error when i tried to run the selected step. (see attachment)
Please tell me the workaround for this.
(2,947 Views)
i have solved it....
infact there is a problem with the DLL.
the step where DLL is used was taking the same DLL from someother location.
i have deleted the step and created it again to make the relative path and made sure only 1 DLL exists.
But i wonder why TestStand did not say that the DLL it was looking for is in different location.
(2,895 Views)
