NI TestStand
Bug in TestStand: relative path remembers previous absolute path
I have a TestStand sequence that uses .NET objects. I want to refer to the parent assembly via relative path (..\bin\Tests.dll)
Originally, the absolute path for this file was E:\git\bin\Tests.dll
It is now 😧\git\bin\Tests.dll
My sequence is currently 😧\git\seq\Bar.seq
So the relative path ..\bin\Tests.dll should be pointing to the 😧 drive version.
But it does not and I cannot seem to force it to no matter what I do. It keeps trying to find it in the original location.
Details
When I try to set relative path (..\bin\Tests.dll) TestStand keeps remembering and complaining about the original absolute path E:\git\bin\Tests.dll
If there is an E:\git\bin\Tests.dll it finds that version and points to it, even though I want the D:\git\bin\Tests.dll version.
If there is not an E:\git\bin\Tests.dll version it does not find anything, even though it should find
How do I get TestStand to get the relative paths to work as they should?
TestStand Engine Version 2016 f1 (16.0.0.193) 32-bit
Sequence Editor Version 16.0.0.193
(2,499 Views)
Accepted by topic author cmz
Found my own problem. Relative path is ..\..\bin\Tests.dll
Missing an extra ..\
(2,498 Views)
