NI TestStand
Build 2 dimensional array to plot a graph by passing UIMessages
Hello guys,
I need some advice, the problem I have is that I want to pass an array[0..5] of numbers to my custom User Interface throwugh UIMessage to plot a graph with that data in the same grapgh (see the behavior of the 6 signals on the same graph) but so far I could only pass one value and see only one signal in the graph.
Is there a way to pass the array trhough the UIMessage using the activeXDataParam? Or maybe other way?
Thanks for your comments.
Eder
(3,706 Views)
Accepted by Eder22
I threw together a simple example in TS 2014 and LV 2014.  I think it does what you want.  Just run the main vi in the project and select the Random Array sequence file.
Also, attached is a picture of my UserMessage vi.
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,687 Views)
Thanks a lot jigg, it does exactly what I wanted.
I really really apreciate your help, thanks again.
Eder
(3,682 Views)
You are welcome.  I'm glad it worked.
jigg
CTA, CLA
testeract.com
(3,675 Views)
