Building a Sequence Using API - (XML) not possible
I uninstalled and installed Teststand today, the same error persists.
The computer is already pretty old and was installed about 10 years ago...
Could it be possible that the Labview VI that read the steps from the xml is only temporarly changed by Teststand and thats why the last save is from 2017 but it keep showing the error ?
Message 11 of 13
(377 Views)
Accepted by NI_JW
Since I have no better idea, I suggest some more experimentation
Make a copy of the Building a Sequence Using API folder and try to do a mass compile with your new LabVIEW version on it
Yet I guess it will error out as well.
Most probably, it is just a simple problem, yet I would have to play around and have this code available
Message 12 of 13
(368 Views)
I created a new sequence File, now it works. The orignal sequence File from NI still causes the error. They both use the same Labview VI...
Message 13 of 13
(338 Views)
