NI TestStand
By default, Teststand will not include the test step result in subsequence, is there any way to include these step result in report?
By default, Teststand will not include the test step result in subsequence, is there any way to include these step results in report?
Jacky
(3,593 Views)
Make sure you have the sequence call step with the record result enabled in the properties.
regards
Ray Farmer
Regards
Ray Farmer
(3,589 Views)
Yes, I have tried that, but the report will not include the limits and the measurement values in subsequence.
(3,588 Views)
If your subsequence is in a separate sequencefile, then check the properties of the sequencefile to make sure that the record has not been disabled.
Regards
Ray Farmer
Regards
Ray Farmer
(3,585 Views)
HI,
Sorry I should have said sequence properties not sequence file properties.
Check that the Disable Result Recording for All Steps has not been enabled.
Regards
Ray Farmer
Regards
Ray Farmer
(3,581 Views)
