NI TestStand
user manager modifications
It seems that under the TestStand directory, if you want to customize anything, one typically creates a User directory and copies the original contents there then begins modifying.  For example, Components and Operator Interface directories have a NI subfolder whose contents get copied into a User.  My question pertains to the Cfg directory.  It doesn't contain an NI directory, so what do I do if I want to modify some of the .ini files in there.  In particular, I want to use the User Manager dialog to add a couple of users, but I don't know if I should create a User dir first.
(3,051 Views)
You dont need to create a User directory for the items in the cfg folder.
If things go wrong, just remove the relevant file and TestStand will create a default version when it starts up.
Regards
Ray Farmer
Message Edited by Ray Farmer on 06-01-2006 06:31 AM
Regards
Ray Farmer
(3,041 Views)
