NI TestStand
C# UI (Teststand 4.2) Exception - Execution is not paused
I'm trying to work on an old Teststand version (4.2) on windows XP for a client that can't justify migrating to newer version of teststand because it is a product that are end-of-life but they aren't dead yet and can't tell when they will be.
I need to be able to extract the failure from the SequenceContext but each time I try to get the SequenceContext, an exception is raised telling "Execution is not paused".
First of all, how to I pause an execution from the C# UI ?
I've tried to get the SequenceContext from the following events without any success :
- axApplicationMgr_UserMessage
- axExecutionViewMgr_EndExecution
- axExecutionViewMgr_Break
- axApplicationMgr_EndExecution
Any idea what I'm doing wrong?
I'm pretty sure it is simple to do but can't figure out what I'm doing wrong..
(2,372 Views)
Accepted by topic author ebonneau9
Ok, I've answered myself to the problem.
I used the ResultObject and ResultStatus to extract the ResultList PropertyObject and extract data.
I that way, no need to get the SequenceContext object and have problem with pausing it.
Hope this helps someone one day.
(2,349 Views)
