NI TestStand
Notification when Teststand update tsxml files
Hi I pass tsxml file path to TestStand FileGlobals, and I want to be notified when Teststand modify in the file
(2,245 Views)
You can place a message pop up step when ever your sequence completes execution, Before Result Processing.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(2,223 Views)
