08-16-2016 05:08 AM - edited 08-16-2016 05:23 AM
I'm attempting to create a WPF application that contains various TestStand UI Elements. I've got the elements displaying however I can't get the sequence file to load in. I can select a file, press open and then a debug message will tell me the file path (which is correct) however axSequenceFileViewMgr doesn't seem to want to update with the contents of the sequence.
Here's my code for reference:
private AxApplicationMgr mAppMgr;
private AxSequenceView axSequenceView;
private AxSequenceFileViewMgr axSequenceFileViewMgr;
private AxButton axButton;
private void WindowLoaded( object sender, RoutedEventArgs e )
WindowsFormsHost host = new WindowsFormsHost();
mAppMgr = new AxApplicationMgr();
host.Child = mAppMgr;
main_layout.Children.Add(host);
mAppMgr.Start();
WindowsFormsHost seq_mgr = new WindowsFormsHost();
axSequenceFileViewMgr = new AxSequenceFileViewMgr();
seq_mgr.Child = axSequenceFileViewMgr;
main_layout.Children.Add( seq_mgr );
WindowsFormsHost button = new WindowsFormsHost();
axButton = new AxButton();
button.Child = axButton;
main_layout.Children.Add( button );
WindowsFormsHost seq_view = new WindowsFormsHost();
axSequenceView = new AxSequenceView();
seq_view.Child = axSequenceView;
main_layout.Children.Add( seq_view );
// Link the button to opening sequence file dlg
axSequenceFileViewMgr.ConnectCommand(axButton, CommandKinds.CommandKind_OpenSequenceFiles, 0, CommandConnectionOptions.CommandConnection_NoOptions);
// Event handler to detect when a file is opened
mAppMgr.DisplaySequenceFile += new NationalInstruments.TestStand.Interop.UI.Ax._ApplicationMgrEvents_DisplaySequenceFileEventHandler(this.axApplicationMgr_DisplaySequenceFile);
private void axApplicationMgr_DisplaySequenceFile( object sender, NationalInstruments.TestStand.Interop.UI.Ax._ApplicationMgrEvents_DisplaySequenceFileEvent e )
MessageBox.Show(e.file.Path);
axSequenceFileViewMgr.SequenceFile = e.file;
}So how do I go about linking axSequenceFileViewMgr and axSequenceView so that when the file is changed, the contents are displayed?
08-16-2016 07:27 AM
// connect sequence view to sequence file view manager
axSequenceFileViewMgr.ConnectSequenceView(axSequenceView);
mAppMgr.Start();
It looks like you did not connect the SequenceView to the SequenceFileViewMgr (see the added code above). I also recommend that you configure all of the manager controls before starting the ApplicationMgr (see the moved code above).
-Jeff
