NI TestStand
CAN Test File Permission Error
Hi Everyone,
Could someone help me with a file permission error when calling CAN test with a different user login account that has full local admin rights.  The error is as follows:
Labview: File permission error.  You do not have the correct permission for this file.  Please refer to attached picture for more details.
We are using TestStand/Labview 2012, SP1 and windows 7.
Thanks very much,
tstand
(4,929 Views)
I have searched the forum for error -18004 but there is no information that could me lead to a solution.
Does anyone had similar problem before?
Does TestStand or Labview requires full local admin rigths per user login account (on Win7)?
tstand
(4,887 Views)
Hi tstand,
Are you able to run the sequence if you're logged in as the Administrator on your computer?  Also, are you able to access the LabVIEW Run Time Engine at all from this user account?  Try running a simple LabVIEW executable.  Can you call LabVIEW code modules from any other steps, or do you receive this error every time you call any LabVIEW code module?
Myriam
(4,877 Views)
Hi Myriam,
Problem solved.  This system was built out of network control, so IT had to make some changes to users login.  I don't have all the details, but is working now.  Thanks for your help,
tstand
(4,857 Views)
