NI TestStand
share queue runtime
Ik have 2 vi's which I want both own the same queue.
- 1 client
- 1 server
In labview development it works.
Does it work in runtime when calling from teststand?
(5,442 Views)
Ok I now put the 2 VI's in a project and call the VI from project in teststand.
Now I see a problem.
When I first start looking for the "Data queue" which the server will create the code will wait for it until it is created.
When I close all and start looking for the queue which will be created by the server I find a queue but I did not create one.
Some how the queue stays in memory because I don't get an error when looking for the queue.
Maybe the project stays in memory?
(5,420 Views)
Greetings,
I am having a hard time understandin the issue you describe. Could you I get you to outline the problem in more detail and even post your code or screenshots of it?
Eirikur Runarsson
(5,356 Views)
It's solved now.
I sometimes have problems with teststand when running a-synch vi's.
Don't exactly know what it is.
(5,236 Views)
InspectorGadget123123
Do you want to share with the rest of us what you did to resolve this, so others in similar situation could have a look?
Also, what problems do you have running asynchronous VIs in TestStand?
Eirikur Runarsson
(5,215 Views)
Well the primary problem was that the CUEUE was not shared between 2 vi's in runtime, when I put them in a project they then share the same memory I guess.
Question still remains, when starting a sequence asynchr why does the sequence waits at the end of the sequence while the asynchr VI is running.
(5,213 Views)
