NI TestStand
Call DLL created by Labview in TestStand
I want to call a DLL created by Labview 7.1 in Teststand3.1.
And DLL will have a Sequence Context as an input parameters and two output parameters(Report, ErrorCluster)
How can I call this dll in teststand. I always fail to pass the Sequence Contest to dll.
BTW, is it possible to use CVI adapter to call dlls created by Labview. It seems CVI adapters can recogonize the parameters directly?
Can I using *TestData and *TestError directly using CVI adapter?
(4,354 Views)
I have not had a problem with the Sequence Context, at least not in LabVIEW 8.5.
I mapped the SequenceContext as follows in the Define VI Prototype window.
Param Type:  Input
VI Input:        Sequence Context
Pass by:       IDispatch Pointer
I would not use the Error Out cluster as a DLL output as these do not map correctly in TestStand, in fact all are not automatically recognized  by TestStand.
To call it from TestStand use the 'C/C++ DLL ' step type. and set the Value Expression to ThisContext.
PH
(4,331 Views)
I have also tried it. And seems that there is no problem to pass the sequence context to DLL from Teststand. However, the Error cluster will never be recognized by Teststand.
And I also followed the instruction from NI's website(Created customer container type in TS, let it pass to C/C++DLL...), but it still fails.
Are there some other methods which can be used to pass the error cluster in Labview when complied to DLLs?
(4,315 Views)
I've just written to the TestStand error container (Result.Error.Code, etc.) in the VI instead of passing it as a parameter.
(4,309 Views)
I do it as follows, and it works great.
21732i95D7502B3A902E0A
(4,208 Views)
