NI TestStand
Call Executable, absolute path doesnt work as expected
Hi all,
i have a problem with the step call executable.
I configure the step (call a .exe or bat file) with absolute path.
As long as Teststand runs with the seq-file loaded all works fine.
The problem shows up when i close the seq-file and reload it later.
Then the configuration seems to be ok (still the absolute path).
But when i execute the seq-file it runs the .exe or .bat file as it only has
the relative path in the configuration.
I know that, because it wanna load some files from the same folder
and it doesn't find them after reloading the seq-file.
Sincerely Stefan Bölsterli
(3,124 Views)
I use Teststand 3.0
(3,122 Views)
