NI TestStand
TestStand 3.0 vs. 3.1 Property flags and Sequence Editor Options.
I'm in the middle of trying to convert an application from TestStand 3.0 to 3.1. This application uses a custom UI and a custom process model. I've opened the 3.0 ver of the process model in 3.1 and saved it under a different name(auto conversion). I've run the diff tool on these and it reports no differences. When I look at the 'Single Pass' entry point using edit>>sequence properties>>advanced (General tab)and compare the 2 versions I've noticed that the 3.1 version doesn't have 'K' properties listed (i.e. kIsCachedProperty). I've also opened NI's 3.1 version of SequentialModel.seq and have not found these 'k' properties. Am I missing a sequence editor option somewhere? I've contacted NI about this and they are looking into it. I'm wondering if anyone else had seen this behavior? I'll post NI's answer when I receive it.
Now Using LabVIEW 2019SP1 and TestStand 2019
(3,008 Views)
To GovBob -
The flags listed with the prefix "k" are internal NI flags that we do not document. And I do not believe that these are saved to disk when a sequence file is saved. These flags should not have been exposed to customer because they just cause questions. They are not accessible via the API either. I believe we just cleaned up the dialog and now hide them. Why are you concerned about these internal NI properties?
Scott Richardson
https://testeract.com
(2,976 Views)
Scott,
Thanks for the answer. I'm in the midst of rebuilding an application that uses a custom UI and Process model. Going from 3.0 to 3.1. Being fairly new at this i was just comparing the two versions trying to make sure I didn't miss anything.
(2,971 Views)
