NI TestStand
Call TestStand using LabVIEW VI
How to call teststand using LabVIEW and update LabVIEW indicator?
both should run parallely and  for this  VI i only pass a file path of sequence.( except UI example suggest me some other example)
best regards
Message 1 of 10
(9,113 Views)
Accepted by topic author ManasaM
Usually you would have a User Interface call TestStand.  The UI can be built in LabVIEW.  Here is document on UI development:
https://www.ni.com/en/support/documentation/supplemental/08/teststand-user-interface-development-bes...
Then you use UI Messages to communicate back and forth between the UI and your sequence file.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x3tWCAQ&l=en-US
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
Message 2 of 10
(9,109 Views)
Thanks a lot
Message 3 of 10
(9,107 Views)
Feel free to post any questions about it here.  It can get a little tricky sometimes.
jigg
CTA, CLA
testeract.com
Message 4 of 10
(9,105 Views)
I am using the VI ( C:\Program Files (x86)\National Instruments\TestStand 2014\UserInterfaces\Simple\LabVIEW\Source Code) which gives an example for simple UI and i am loading simple Teststand seq which has only message pop step and for loop with i and N intialisation .
Now i need to see the i and N values in my LabVIEW indicator I know how to read but in this Example i am not getting where to add my code?
Message 5 of 10
(9,090 Views)
Where are you getting the sequence context from?  Did you read the article on UI Messages?  I'm not sure you are doing it correctly.
jigg
CTA, CLA
testeract.com
Message 6 of 10
(9,069 Views)
Hi
I didnot read UI article before, Now I read its a great article .
Thanks a lot
Best Regards
Manasa
Message 7 of 10
(9,042 Views)
Hi
I have created User message callback in reg event call back in simple UI example. after that created subVI call back and writen this code stilli am not able to update teststand variables values in labview please suggest me if anything wrong
regards
MGL
Message 8 of 10
(9,017 Views)
You need to pass a reference to your front panel control and then use a property node to set the value.  You cannot pass the value like that.
Hope this helps,
jigg
CTA, CLA
testeract.com
Message 9 of 10
(9,006 Views)
You are on the right track though.
jigg
CTA, CLA
testeract.com
Message 10 of 10
(9,005 Views)
