NI TestStand
I want to change serial number in the Batch report and in the special UUT report
I use Batch Model, sequential mode.
I want to change serial number in the Batch report and I want to change UUT serial number in each TestSocket report.
I overrided ModifyReportHeader, I did
Parameters.UUT.SerialNumber = "....."
but the serial number changed only in the Batch Report, not in UUT Report. How can I change serial number in UUT Report too?
(3,612 Views)
Marta,
There is actually a ModifyBatchReportHeader in addition to the ModifyReportHeader that you already used.  That would be the first thing to do.
After that, I think I need a more detailed description of what you are trying to do (perhaps with screenshots) in order to be able to help effectively.
Josh W. | National Instruments | Applications Engineering
Josh W.
Certified TestStand Architect
Formerly blue
(3,595 Views)
I always successed to do it. Anyway thank's 🙂
(3,574 Views)
Please tell me how you changed the serial numbers in the UUT Report for each socket?
(3,066 Views)
