NI TestStand
Call sequence from another file
I am trying to call an externally saved sequence into my main sequence, but to no avail.
When I choose both: "Specify by expression" and "Use current file" option I am able to select sequence programmatically.
But When I want to select a sequence from an another file, Test stand tell me that there is an error, but does not specify the error.
How Do I accomplish that?
please see attached example.
Gil,
(1,157 Views)
Hi Gil,
You should study TestStand examples firstly, those examples taught us how to call sequence. And back to your questions, you need is to give it the right path.
Ricky
(1,114 Views)
