NI TestStand
TestStand deployment utility does cannot locate Vis that Labivew project reference
Yes TestStand I see that you cannot find project VIs, BUT PLEASE TELL ME WHAT VI SPECIFICALLY IS THE ISSUE??!?!?!!?!?
(1,271 Views)
Are there any missing VIs if you open this project in LabVIEW?
Are there any problems with your sequence if you run sequence analysis?
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(1,231 Views)
No!
(1,217 Views)
