NI TestStand
Calling .NET DLL Error
Hi everyone
I'm trying to make a TCP/IP connection with a PLC, using an open source DLL wrriten in .NET (This Library)
first of all I create an Action Step, and call the object ModbusClient and the Connect method:
ModbusClient().Connect("device ip", port)
then I create the second Action Step, and call the WriteSingleCoil method to write a True status to Address 8193:
ModbusClient().WriteSingleCoil(8193,True)
after second step execution I get an exception error: connection error
it seems that first step execute independently and when the program execute the second step, the connected TCP/IP connection at the first step does not exist anymore.
I've read somewhere that we must store Object Reference in a Local variable and define it in the rest of the functions in different steps.. but I don't know what it means and don't know what to do..
I'm quite new to Teststand.. can anybody help ??
Thank you, Eric.
(2,527 Views)
Hi Eric jan,
Check this link, for the part of Local variables.
And also take a look at this, for TestStand.
Regards.
(2,482 Views)
Accepted by ericmateovisan
Hi ericmateovisan,
You can create first object  reference then  use "Use Existing Object(EasyModbus.ModbusClient).Connect(System.String, Int32)" in your next steps.
1.   Create object   .NET Invocation = ModbusClient(), return value is object  reference
2.  .NET Invocation= Use Existing Object(EasyModbus.ModbusClient).Connect(System.String, Int32)
3.  .NET Invocation=  Existing Object(EasyModbus.ModbusClient).WriteSingleCoil(Int32, Boolean)
important point is here, that you need to use only existing object.
check it please here  topic: Use Existing Object
https://www.ni.com/docs/en-US/bundle/teststand-api-reference/page/tsref/module-tab-edit-net-call-dia...
(2,459 Views)
@IDASYAN wrote:
Hi Eric jan,
Regards.
Thank you for your reply 👌
(2,445 Views)
@sezgin.caluk wrote:
Hi ericmateovisan,
thank you for your reply... this solved my problem. thank you so much 😊💙
(2,442 Views)
