NI TestStand
Calling SequenceFilePostResultListEntry doesn't change recorded result output
Hi Everyone,
I'm trying to use SequenceFilePostResultListEntry to discard some step results.
But when I launch the test (UUT or SinglePass entry point), I can still see the results on the report,
despite the parameter DiscardResult on True for all steps.
I noticed too (by setting, Parameters.Step.Result.Status = "Failed" in SequenceFilePostResultListEntry sequence),
that the execution pane shows the steps at failed but "Passed" on the report pane.
Does anyone knows about those behavior ? Is there an option I may have forgotten ?
Please see the attached sequence file.
Thanks for your participation...
(3,933 Views)
Running your sequence on my machine works as expected.
No results are available, so the report consists of the header and then states:
No Sequence Results Found
Do you use a default process model?
Which version of TestStand?
Do you use On-The-Fly reporting?
Norbert
Norbert
Expert: Geometry
(3,926 Views)
Accepted by LMartin
Great Is working now,
I was using on-the-fly reporting.
Thanks Norbert !
PS: I'm using TestStand 4.2.1 with the SequentialModel.seq as process model
(3,923 Views)
