Calling Shutdown() causes a StartExecution event and an EndExecution event
When my application is terminating it calls the following code from my Form Closing callback:
    if (this.axApplicationMgr.Shutdown() == false)
        e.Cancel = true;
    else
But before the ExitApplication event occurs, a StartExecution event and an EndExecution event occur.  Where are these extraneous events coming from and how can I get rid of them?
(3,379 Views)
It's probably of the LoginLogout sequence in FrontEndCallbacks.seq performing a logout.
Since the event has a reference to the execution, grab it and call Execution.GetSequenceFile() to see.
Message Edited by asbo on 06-17-2010 11:00 AM
(3,377 Views)
Yes both events are indeed from LoginLogout in FrontEndCallbacks.
Ok, so these events are part of the normal function of shutting down and they are not anything I should be concerned about, right?
(3,368 Views)
Accepted by tlaford
This is normal.
(3,354 Views)
