NI TestStand
Calling labview-vi and set Visa Resource Name
i inserted an instrument driver which was downloaded from ni website.
In here all the VIs like "initialiate, Reset, Selftest" have the parameter VISA Resource Name.
The value for VISA Resource Name.Device Name and VISA Resource Name.Session Number is stored in StationGlobals.
Currently i manually add this global link to the Parameter value.
Is there a faster way to do this? Like a preexpression?
Thx
(1,236 Views)
I am not sure if i fully understood your question.
However each step in TestStand has a pre expresssion and also post expression.
Go to Properties tab of the step and click on the expressions.
Ravi
(1,179 Views)
I mean someting else.
After inserting the vi in an empty Labview-action-step i can see all of itzs parameters in the module tab.
One of the parameters that all vis have is parameter "VISA Resource Name".
This container contains:
I also have the two StationGlobals.
StationGlobals.Project.Device and
StationGlobals.Project.Session
Is there a way to set a PreExpression to write the StationGlobals in the vi-parameters WITHOUT changing the parameter value. Only by a preexpression.
(1,173 Views)
So you want to have a pre-expression which assigns the according data from your station globals as values for the code module parameters, but you don't want to have this assignment saved in the sequence file (WITHOUT changing the parameter value)?
To get the data to and from a code module, you technically have to change the parameter value
(1,168 Views)
Correct
(1,163 Views)
Having a breakpoint before a step using a VI Call gives theoretical access to the parameters
RunState.Sequence.Main["Numeric Limit Test"].TS.SData.ViCall.Parms
You have to consider yourself how maintainable this is.
(1,153 Views)
