NI TestStand
TestStand Deployment build error -19039
I am trying to move a working test environment written in Labview2015sp1 and Teststand2016 to Labview2018sp1 and Teststand2022q4.
I upgraded the VIs and sequences first without any big problems, however when I try to build the project I get error -19039.
It would seem to be a Labview version-related error, however I find this strange as from the specifications the Teststand2022 and Labview2018sp1 should be compatible.
Any suggestions would be greatly appreciated
(1,127 Views)
Accepted by topic author EnzoM
Hi Enzo,
LV 2018 sp1 is allowed but not supported with TS 2022 Q4. What that means is it can be used in some cases like for execution but for deployment, the TS Deployment Utility only allows using the least supported LV version or higher. For TS 2022 Q4 that would be LV 2019 like the error message indicates.
This is not an error but expected behavior.
Tinu
(1,020 Views)
Hi Tinu,
Thank you very much for your response.
The error message was clear, however it did not agree with the compatibility table I had found on the NI site, which at this point I would say that is not very clear.
Anyway I got it and upgraded the Labview code to a higher version.
Regards
Enzo
(1,010 Views)
Hi Enzo,
I agree, the table is misleading! If you can just post the link to it, i can talk to someone to see if we can make this more clear at least for the newer versions.
Tinu
(1,006 Views)
(1,003 Views)
