NI TestStand
Calling subsequences from within a file w LV 7.1?
I have a sequence I'll call Main Menu.seq (TS3.1).  Within Main Menu I have sub sequences Menu 1, Menu 2 ...  Using LabView 7.1 can I call anyone of these sub sequences ??  I've used LV before with the SYSEXEC.vi to call a seq but not only did I have to create Main Menu.seq but an invdividual Menu1.seq, Menu2.seq.  My goal is to write a seq ( Main Menu) that runs top to bottom with a click of a button either in LV or some other method.  I just call Main Menu seq and it runs Setup, Menu1, Menu2 ..Cleanup.  I also want to allow the user to be able ( through a button selection ) be able to run an individual sub seq w/o running the others ( expect I DO want to run Setup and Cleanup in TS if an individual sub seq is selected)..
(2,871 Views)
Hi Clint Eastwood,
There are several options that you have for calling sequences and sub-sequences from LabVIEW.
Option 1: Use the built-in operator interfaces (graphical user interfaces used for executing sequences) that ship with TestStand. In the folder C:\Program Files\National Instruments\TestStand 3.1\OperatorInterfaces\NI, you will find full-featured and simple versions of operator interfaces.  In all the operator interfaces, you can select to run either the main sequence or sub-sequences.  You also have other features within these operator interfaces such as starting multiple concurrent executions, setting breakpoints, and single-stepping. Here is a link to a relevant thread and also a Simple LabVIEW Operator Interface without Menus program
Option 2: Attached code is a VERY simplified hard-coded way of running a sequence. It involves using the Application Manager and SequenceFileView Manager.  Basically the program opens a sequence file, chooses a sequence (GetSequence -- Index is used to differentiate sequences) and then runs the sequence.
I would recommend using the operator interfaces since it provides you will maximum functionality.
Hope this helps!
Best Regards,
Jonathan N.
(2,853 Views)
