Can 64bit TestStand run 32bit Labview
Can 2016 64bit TestStand run 32bit Labview? The Labview calls 32bit Dlls.
I don't think so, but I'm looking for comformation. I think TS is recompiling the Labview as 64bit...
(2,885 Views)
TestStand cannot recompile your VIs.  If it opens LabVIEW 64-bit, that will recompile your VIs.  So you should go into your adapter settings and see what TestStand is using to load your VIs.
Some additional information: Adapter and Code Module Support for 64-bit TestStand
GCentral
(2,863 Views)
You can't load 32-bit DLLs in a 64-bit process but there are some workarounds by calling them in an external process:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YGjoCAG&l=en-US
Hope this helps,
Trent
(2,830 Views)
