NI TestStand
Can I make the TestStand Properties dialog an 'always on top' window?
I am having window Z order problems, such that calling PropertyObject.DisplayPropertiesDialog() sometimes sends the window behind the my application window. This causes people to think that the application has crashed (it's only waiting for them to dismiss the properties dialog), and often results in the fatal three finger salute.
This problem cannot be solved by setting Engine.AppMainHwnd, or using the PropDlgOption_ModalToAppMainWind option - it's a long story. Is there a way to set the Z-order priority of TestStand dialogs? If I could set the dialog to 'always on top', all my problems would be solved.
Aaron Stibich
Senior Engineer
Innovative Technologies Inc.
(2,967 Views)
Hi Aaron,
Unfortunately there is no way in TestStand to set the Z order property. You may be able to use Windows API calls though to accomplish the same goal. I will however put in a product suggestion for you so that this request may be looked at.
Caroline
Caroline Tipton
Data Management Product Manager
(2,953 Views)
