NI TestStand
How do you keep two executions from interfering with each other when they share the same GPIB card?
I have written a teststand sequence that controls multiple ovens. When you start an execution you select which oven that execution controls. The problem I am having is that when multiple execution are run, the sequence hangs. I believe this to be caused by both executions sharing the same gpib bus. How do you keep two application/executions from interfering with each other when they share the same GPIB card using VISA Read/Write Commands?
(2,981 Views)
You need to setup synchronisation on your gpib steps.
There is a nice little example that show this with comments, found in your TestStand examples in \MultiUUT\ called BatchUUT.seq.
The Pulse Test is setup as a subsequence which contains a group of steps that are synchronized to run on each UUT in turn. The subsequence simulates sharing an single instrument that you must use one each UUT one at a time.
I hope this helps
Regards
Ray Farmer
Regards
Ray Farmer
(2,980 Views)
