You need to setup synchronisation on your gpib steps.
There is a nice little example that show this with comments, found in your TestStand examples in \MultiUUT\ called BatchUUT.seq.
The Pulse Test is setup as a subsequence which contains a group of steps that are synchronized to run on each UUT in turn. The subsequence simulates sharing an single instrument that you must use one each UUT one at a time.
I hope this helps
Regards
Ray Farmer
Regards
Ray Farmer
