NI TestStand
Can I use property loader in a main sequence to load properties in subsequence?
In the PropertyLoader step, change the Start and End Marker to
"Start_<Sequence>" and "End_<Sequence>"
Regards
Ray Farmer
Message 11 of 14
(1,353 Views)
Hi Ray,
Thanks that worked, but if my start and stop markers are not defined does that mean in order to load a different set of limits I would need to call a seperate file?
Kind regards,
Hugo.
Message 12 of 14
(1,349 Views)
Accepted by topic author Hugo11
Not necessarily so, you would have to set your Start and End markers so that it takes in the <sequence> tag and also the different sets flag eg
"Start_Sequence>_"+Locals.set[Locals.index]
But it might be tidier if different sets of limits are contained in different files based on the unit under test, easier to control and maintain.
Regards
Ray Farmer
Message 13 of 14
(1,347 Views)
Thanks for all your help, much apreciated.
Message 14 of 14
(1,338 Views)
