NI TestStand
Can Station Gloabals from different versions of TestStand be used with TestStand 2010?
I have an older version of TS - ver. 4.01.  I just renewed my subscription and have 2010 now.  Can StationGlobals from one version be copied directly into the cfg directory of a different version?  It appears to work, but I want to make sure there are no underlying problems.
(2,848 Views)
Seems like you have answered your own question. When TestStand closes it will update the StationGlobals.ini file so if you were going to have any problems you probably would have seen it then.
Regards
Ray Farmer
(2,843 Views)
