NI TestStand
Errors in application log
I've been having troubles with TestStand and started to see this in the application log. Anyone knows what causes this or how it can be corrected?
The description for Event ID ( 0 ) in Source ( NI Variable Engine ) cannot be found. The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer. You may be able to use the /AUXSOURCE= flag to retrieve this description; see Help and Support for details. The following information is part of the event:
NI Variable Engine started.
Executable: C:\Program Files\National Instruments\Shared\Tagger\tagsrv.exe
Plug In Path: C:\Program Files\National Instruments\Shared\Tagger\
Plug Ins: LogosRTServer, LogosRTClient.
(2,864 Views)
checkout the following post as this seemed to have a similar problem
http://forums.ni.com/t5/Measurement-Studio-for-NET/Tagsrv-exe-C-Runtime-Error-When-Shutting-Down-PC/...
Regards
Ray Farmer
(2,856 Views)
