Home
Community
Discussion Forums
Most Active Software Boards
NI TestStand
Topic
NI TestStand
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Can test stand execute LabVIEW executables ?
jpday
Member
07-07-2005
09:39 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Can I refer to LabVIEW executables in testand -> I can run VIs developed in LabVIEW through Teststand with only the LabVIEW runtime engine on the host computer ?
0
Kudos
Message
1
of 3
(3,057 Views)
Reply
Re: Can test stand execute LabVIEW executables ?
Dennis_Knutson
Knight of NI
07-07-2005
09:41 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Sure. The easiest way is to build a DLL and not exe and use TestStand's DLL adapter.
0
Kudos
Message
2
of 3
(3,054 Views)
Reply
Scott_Richardso
n
Active Participant
07-19-2005
03:42 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
What version of TestStand are you using and what version of LabVIEW are you using?
Scott Richardson
https://testeract.com
0
Kudos
Message
3
of 3
(3,017 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
