NI TestStand
Can test stand execute LabVIEW executables ?
Can I refer to LabVIEW executables in testand -> I can run VIs developed in LabVIEW through Teststand with only the LabVIEW runtime engine on the host computer ?
(3,038 Views)
Sure. The easiest way is to build a DLL and not exe and use TestStand's DLL adapter.
(3,035 Views)
What version of TestStand are you using and what version of LabVIEW are you using?
Scott Richardson
https://testeract.com
(2,998 Views)
