NI TestStand
Change Initial Path for searching for Sequence files
When I use the File menu "Open" command after initially opening TestStand, the search for any sequences starts in the C:\Program Files\National Instruments\TestStand 3.1 directory.
All of my sequences are located in the C:\TestStand directory.
Is there a way to modify the Path settings in TestStand to start it's search in the C:\TestStand directory?
Mike
Message 1 of 14
(5,658 Views)
Mike
Mike,
I believe there used to be an NI knowledgebase article which tells you how to do this. Basically you need to modify TestStand's FrontEndCallback sequence by adding an action step which calls the SetCurrentDirectoryA function in the OS kernel.
Copy C:\TestStand\Components\NI\Callbacks\FrontEnd\FrontEndCallbacks.seq to C:\TestStand\Components\User\Callbacks\FrontEnd\FrontEndCallbacks.seq, open the file in the sequence editor and add an action step above the logout and login steps. This works for us with TestStand 2.0.
Terry Dano
Harris Corporation
Message 2 of 14
(5,647 Views)
Hi Mike,
Here's a link to the KnowledgeBase Terry mentioned:
http://digital.ni.com/public.nsf/websearch/365DC2996F67D8AF86256AF000558B90?OpenDocument
I hope this helps!
Sarah Miracle
Message 3 of 14
(5,637 Views)
Thanks for the Replies,
I had searched the site yesterday before posting, but didn't find anything. I did find the article that Terry referenced and it was the same basic functionality of the article that Sarah referenced.
I did get the "FrontEndCallbacks.seq" modified and got it working. A bit disappointed that it's not an internal setting to TestStand though, that you need to make a Windows DLL call to get away from the default "C:\Program Files\TestStand 3.1" which is useless.
Mike
Message 4 of 14
(5,640 Views)
Mike
Hi
One way to change the initial working directory ie the directory in which file open dialog opens is to change the "Start in" location for the short cut to the sequence editor or any other executable. This can be done in the properties dialog as shown in the attached bitmap.
Hope this helps.
Reagrds
Anand Jain
National Instruments.
Message 5 of 14
(5,629 Views)
Anand,
Much better solution!!
Mike
Message 6 of 14
(5,616 Views)
Anand,
Mike
Message 7 of 14
(5,614 Views)
I have a client who needed to do something similar. Essentially, they wanted to switch between a "Production" and an "Engineering" environment. I added a Boolean switch on the front panel of their customized OI, and made a call to the DLL referenced in this thread from another example I found on NI's site:
This way, you don'y need to modify a .seq at all, and you can switch programatically. I also am going to use a .ini, or TestStand resource file to configure these directories outside of LabVIEW.
Message Edited by gnange on 04-25-2006 03:00 PM
Message 8 of 14
(5,316 Views)
Hi:
Do these suggestions still work for Teststand 4?
I'd like to do the same thing - change the default directory from which the operator interface opens sequence files.
However, I've tried both updating the FrontEndCallback with SetCurrentDirectoryA and updating the working directory in my operator interface shortcut. Neither of these solutions worked for me.
I'm using the Teststand 4 CVI Full Featured Operator interface.
Dave
Message 9 of 14
(4,777 Views)
Hey Dave,
I have successfully used the shortcut method with the CVI User Interface for TestStand 4.0.  Can you try on another computer?
Andy McRorie
NI R&D
Message 10 of 14
(4,748 Views)
