NI TestStand
Change Step.Result.Status of calling sequence
This is an example of my structure:
The MainSequence contains some Sequences and each of them have a CheckSequence at Setup:
  • Sequence1
    • CheckSequence
  • Sequence2
    • CheckSequence
  • Sequence3
    • CheckSequence
Now I want to set the Step.Result.Status of the Sequence1,2 or 3 within the CheckSequence. I've tried this Statement, but it does not set the Status:
RunState.Caller.Caller.Step.Result.Status = "Skipped"
(1,870 Views)
Does nobody have a hint or solution?
(1,814 Views)
Accepted by topic author Struct
(1,808 Views)
