Change UUT serial Number with Single Pass in Batch model
Norbert,
Can't change "Conserve Memory".  It's disabled.
Don't want to uncheck "OnTheFly Reporting" because I want test results being recorded as soon as a step/test is done.  Don't want to loss test results in case any error occurs.
Thanks for your help.
George
George Zou
Message 11 of 12
(1,022 Views)
Georg,
if there is an error, TestStand still creates the report. This does not change regardless of standard reporting or OTFR....
The only way to have OTFR create a report where standard reporting does not is a complete systemcrash during runtime. And with such a crash there is still the possibility that the file written by OTFR is corrupt and cannot be read.
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 12 of 12
(998 Views)
