NI TestStand
Change step description
In main sequence I copied/pasted a case statment. Was able to change the name of the sequence step within the new case but cannot figure out how to change its description.
thanx,
jvh
(4,735 Views)
The description is the Value to Compare for the statement. What do you want it to be? In order to modify it, you would have to copy the step, rename to something else, and edit the Step Description Expression
(4,732 Views)
Accepted by topic author jvh75021
Thanks for posting. I copied and renamed but having trouble finding how to edit the Step Description Expression. I can see it but it is greyed out, not editable.
(4,723 Views)
Where did you do the copy? I just created a sequence and added a case statement. Went to the step editor and selected that new sequence. Copied the case step, pasted it, and it create NI_Flow_Case_2 that is editable.
(4,719 Views)
Maybe we should just move on to my newer thread. In the main sequence I copied an entire case in a Select statement and pasted it just above it. Perhaps this is not kosher.
jvh
(4,715 Views)
Hi
Please post a screenshot which shows what you like to do
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(4,694 Views)
