NI TestStand
Database Logging Error, TestStand 4.1.1
Hello everyone--
I am getting the following Database Logging error ONLY on String-Value Type statements.  As a note, I have generated a custom schema : ACA UTS Generic Insert and it works fine for all other step types.
An error occurred calling 'LogResults' in 'ITSDBLog' of 'zNI TestStand Database Logging'
An error occurred executing a statement.
Schema: ACA UTS Generic Insert
Statement: PROP_RESULT.
Description: Data type mismatch in criteria expression.
Number: -2147217913
NativeError: -539888598
SQLState: 3464
Reported by: Microsoft JET Database Engine
Source: TSDBLog
Anyone have a starting point where I could look to find out more information what might be wrong?
Paul Holzrichter
(3,829 Views)
(3,815 Views)
The error comes about due to the fact that the 'Property Result' table created contained a DATA column that was actually a number NOT a string.    The reason this occurred will be explained shortly....
For my environment I initially copied a schema and renamed it to ACA UTS Generic Insert.... I added a couple of new tables and new columns to the schema.  When I went to the 'Schema's tab and clicked on Validate against my empty database it noticed that all the tables were NOT found.  Then I selected the 'Build .sql File...' button and created the SQL File.  Opening the SQL file, I noticed the following:
2+ statements to create the PROP_RESULT table!!!
CREATE TABLE PROP_RESULT (
ID GUID CONSTRAINT TABLE_CONSTRAINT PRIMARY KEY,
STEP_RESULT GUID,
PROP_PARENT GUID,
ORDER_NUMBER Long,
NAME VarChar(255),
PATH LongText,
CATEGORY Long,
TYPE_VALUE Long,
TYPE_NAME VarChar(255),
DISPLAY_FORMAT VarChar(32),
DATA Double,
CONSTRAINT STEP_NUMERICLIMIT1_FK FOREIGN KEY (STEP_RESULT) REFERENCES STEP_RESULT (ID))
STEP_RESULT GUID,
PROP_PARENT GUID,
ORDER_NUMBER Long,
NAME VarChar(255),
PATH VarChar(255),
CATEGORY Long,
TYPE_VALUE Long,
DATA VarChar(255),
CONSTRAINT PROP_MULTINUMERICLIMIT1_FK FOREIGN KEY (STEP_RESULT) REFERENCES STEP_RESULT (ID),
CONSTRAINT PROP_MULTINUMERICLIMIT1_FK FOREIGN KEY (PROP_PARENT) REFERENCES PROP_RESULT (ID))
So when I ran the Execute SQL command in the Database Viewer, it created the PROP_RESULT table based on the first SQL command it found, and made the DATA column a DOUBLE instead of a string.
My conclusion is that with my limited knowledge of SQL I did not notice that the file had multiple statements to create the tables.   I modified the NI SQL file for the NI Insert Command to add my custom items and everything worked correctly.
Paul Smiley Very Happy
(3,809 Views)
