NI TestStand
Change the look of message windows by socket
I am using TestStand to control testing two UUT's at a time. The issue is I need to change the look and feel of the information windows for each socket. It is difficult for the operator to see which UUT (socket) is associated with which message window. I would prefer to use generic text in the message boxes; is there a variable that indicates which socket is in effect for that message call so I can use it in the message?
David W.
Melbourne, Florida
(3,340 Views)
Accepted by topic author dk-info
RunState.TestSockets.MyIndex
Use this variable to determine which socket is running.
(3,324 Views)
