NI TestStand
Passing a Post Expression through multiple sequences
Hi All,
My current sequence has multiple layers (nests).  I am searching for a way to pass my post expression information when my step fails through multiple layers of my sequence.
Here is a description of my "nested" structure:
Main Sequence
         Sub Sequence A
                 Sub Sequence B
I need to be able to pass my post expression information (step failure information) from Sub Sequence B up to the Main sequence?
1.) I would assume the path would be Sub Sequence B....Sub sequence A .... Main Sequence?
OR
2.) Could I go from Sub Sequence b directly to the Main Sequence?
Thanks!!!
(3,401 Views)
I am not sure why you need the information in the main sequence.
I would be tempted to use PostStepFailureCallback to acheive this.
A good example ships with teststand:
C:\Users\Public\Documents\National Instruments\TestStand <version>\Examples\Callbacks\PostStepFailureCallback\FailureHandlerExample.seq
Hope this helps.
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(3,388 Views)
