NI TestStand
Changing Enable tracing station options from sequence file
I can set the Property to enable/disable tracing using the Active X [Set property for TracingEnabled]
Once this tracing is enabled is there a way to enable/disable the "Allow Tracing into Setup/Cleanup" option using Active X?
Vidula
(2,826 Views)
Hi Vidula,
You can get to the individual tracing options through a mask property called ExecutionMask. This is a property of Engine.StationOptions.
StationOptions.ExecutionMask
The Execution Mask constant you want to set is:
ExecMask_TraceIntoSetupCleanup
Hope this helps!
Jervin Justin
NI TestStand Product Manager
(2,807 Views)
